HOW TO
The process of adding a Web Map Tile Service (WMTS) to ArcGIS Online and Portal for ArcGIS using ArcGIS API for Python differs from the process of adding other item types. When using the 'arcgis.gis.ContentManager.add' method, the most important property to consider is the 'text' property.
A sample script to add a WMTS to ArcGIS Online and Portal for ArcGIS is shown below:
from arcgis import GIS
gis = GIS("https://machine.domain.com", "user", "password")
item_prop = {'title':'Test_WMTS',
'url':'https://sampleURL/WMTS',
'description': 'Test Add',
'tags': 'ogc',
'type': 'WMTS',
'text': {"templateUrl":"https://sampleURL/WMTS/tile/1.0.0/sampleLayer/default/default028mm/{level}/{row}/{col}.png",
"copyright":"","fullExtent":{"xmin":-19840230.38989966,"ymin":2144435.340699963,"xmax":-7452840.465199874,"ymax":11536810.662599582,"spatialReference":{"wkid":102100}},"tileInfo":{"rows":256,"cols":256,"dpi":96,
"origin":{"x":-20037508.342787,"y":20037508.342787,"spatialReference":{"wkid":102100}},"spatialReference":{"wkid":102100},"lods":[{"level":0,"levelValue":"0","resolution":156543.03392798046,"scale":591658710.9089025},
{"level":1,"levelValue":"1","resolution":78271.5169639901,"scale":295829355.4544507},{"level":2,"levelValue":"2","resolution":39135.75848199517,"scale":147914677.72722584},{"level":3,"levelValue":"3",
"resolution":19567.879240997456,"scale":73957338.86361243},{"level":4,"levelValue":"4","resolution":9783.939620498726,"scale":36978669.43180621},{"level":5,"levelValue":"5","resolution":4891.969810249364,
"scale":18489334.715903107},{"level":6,"levelValue":"6","resolution":2445.984905124682,"scale":9244667.357951554},{"level":7,"levelValue":"7","resolution":1222.992452562341,"scale":4622333.678975777},
{"level":8,"levelValue":"8","resolution":611.4962262813027,"scale":2311166.8394883885},{"level":9,"levelValue":"9","resolution":305.74811314051914,"scale":1155583.4197436941},{"level":10,"levelValue":"10",
"resolution":152.87405657039182,"scale":577791.7098723471},{"level":11,"levelValue":"11","resolution":76.43702828506362,"scale":288895.85493567353},{"level":12,"levelValue":"12","resolution":38.21851414253181,"scale":144447.92746783677},
{"level":13,"levelValue":"13","resolution":19.109257071265905,"scale":72223.96373391838}]},"wmtsInfo":{"url":"https://sampleURL/WMTS",
"layerIdentifier":"sampleLayer","tileMatrixSet":"default028mm"}},
'extent': '-178.2278219969978,18.910787002877576,-66.95000499993604,71.38957425051252'
add_wmts = gis.content.add(item_properties=item_prop)
The 'text' property determines how the WMTS is displayed, and proper definition of this property is essential for the service to display correctly.
Follow the instructions below to add a WMTS to ArcGIS Online or Portal for ArcGIS using ArcGIS API for Python.
Article ID: 000021946
Get help from ArcGIS experts
Start chatting now
