HOW TO
This article shows how to add a non-geodatabase Access table to ArcMap using VBA and ArcObjects.
Code in ThisDocument module will only run in the current map document. To store the code in all your map documents, open the Normal.mxt ThisDocument code module.
Code:
Sub AddTable()
' Get the table from the workspace factory
Dim pWf As IWorkspaceFactory
Set pWf = New AccessWorkspaceFactory
Dim pWs As IFeatureWorkspace
Set pWs = pWf.OpenFromFile("c:\incidents\February\DF\db2.mdb", 0)
Dim pTable As ITable
Set pTable = pWs.OpenTable("Dogs")
' Get a Standalone Table
Dim pStTable As IStandaloneTable
Set pStTable = New StandaloneTable
Set pStTable.Table = pTable
' Add the table to ArcMap
Dim pDoc As IMxDocument
Set pDoc = ThisDocument
Dim pMap As IMap
Set pMap = pDoc.FocusMap
Dim pTc As IStandaloneTableCollection
Set pTc = pMap
pTc.AddStandaloneTable pStTable
' Refresh the View and Table of Contents
pDoc.ActiveView.Refresh
pDoc.UpdateContents
End Sub
Article ID:000004949
Get help from ArcGIS experts
Download the Esri Support App
