HOW TO
add a -NONE option to a form menu INPUT CHOICE
Procedure
The form menu INPUT widget does not have a -NONE option; how can it be added to an INPUT widget using the CHOICE option?
Answer:
Add an option called _NONE_ to the list of choices for that widget. In the return string for that widget add the following action:
&IF [QUOTE %< widget_variable >%] = '_NONE_' &THEN &SET %< widget_variable >%
This allows the variable to be set and exist while containing a null.
Article ID:000001362
Software:
  • ArcMap 8 x
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
