HOW TO
Activate the Table Of Contents in ArcMap
First Published: May 5, 2016
Last Published: July 21, 2025
Summary
The Table Of Contents is crucial for the activation of map layers, accessing the properties of layers, and rearranging layers to change the drawing order. The instructions provided describe how to display the Table Of Contents in ArcMap if it is not in view.
The image below shows the Table Of Contents in ArcMap 10.x.
The Table Of Contents in ArcGIS Desktop version 10.
The image below shows the Table of Contents in ArcMap 9.x.
The Table Of Contents in ArcGIS Desktop version 9.
Procedure
In both ArcMap 9.x and 10.x, activate the Table Of Contents by navigating to the Main menu, and click Windows > Table Of Contents.
In some instances, the Table Of Contents displays as a tab at the top-left corner of the data frame view. To open the Table Of Contents, hover over the tab and click the Auto Hide button (pin symbol) located at the top-right corner, next to the Close button. This fixes the Table Of Contents to its location.
The image below shows the Table Of Contents that displays as a tab at the top-left corner of the data frame view.
This is the Table of Content that displays as a tab.
The image below shows the Auto Hide button (push pin icon) that when clicked, fixes the Table Of Contents to the data frame.
This is the Auto Hide button.
Adjust the width of the Table Of Contents by hovering the pointer at the edge of the window and clicking the mouse while adjusting the size of the Table Of Contents.
To dock the Table Of Contents pane to a desired location (for example, to the left side), drag the Table Of Contents pane to the left, and hover over the left blue arrow using the cursor. The Table Of Contents is ready to be docked when the blue shadow pane appears.
The Table Of Contents ready to be docked to the left side of the map view.
Article ID: 000010217
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
