HOW TO
Access the sublayers of a non-hosted ArcGIS Online map image layer
Last Published: August 14, 2020
Summary
In some cases, it is necessary to use a non-hosted ArcGIS Online map image layer for data analysis. However, a map image layer is limited in editing and data analysis capabilities. It is primarily used as a form of visualization. Refer to ArcGIS Pro: Share a map image layer for more information.
A map image layer includes both feature and non-feature layers as its sublayers. These sublayers are used to perform different types of data analyses.
Procedure
To access the sublayers of a non-hosted map image layer from ArcGIS Online, follow one of the options below.
ArcGIS Desktop
In ArcMap, the map image layer from ArcGIS Online is accessible but non-editable.
In ArcGIS Pro, it is possible to access and edit the map image sublayers.
  1. Click the Map tab, and click Add Data > Data.
  2. In the Add Data window, click Portal > All Portal. Search for the map image layer.
  3. Double-click the map image layer, and select the feature layers in the map image layer.
  4. Click OK.
Image of the Add Data window
ArcGIS Online
  1. Locate the URL(s) of the map image sublayers.
    1. Log in to ArcGIS Online, and search for the map image layer.
    2. Open the item details page, and click the layers in the map image.
    3. In the ArcGIS REST Services Directory, the map image sublayers are under Layers.
    4. Click one of the feature layers, and copy the URL.
  2. Use the URL from Step 1d to add the feature layer in ArcGIS Online.
Article ID: 000022750
Software:
  • ArcGIS Desktop
  • ArcGIS Online
Download the Esri Support App
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
