PROBLEM
Unable to configure ArcGIS Data Store Spatiotemporal Big Data, Graph, and Object stores
First Published: May 21, 2024
Last Published: May 21, 2024
ArcGIS Data Store 11.2 configuration
In ArcGIS Enterprise, when attempting to configure a Spatiotemporal big data store, Graph Store, or Object Store, an issue may be encountered with the ArcGIS Data Store Configuration Wizard where these options cannot be selected or are grayed out, as shown in the next image.
Data store configuration options are inactive or unavailable
A similar issue occurs when attempting to use the configuredatastore.bat utility to configure one of these options, which provides more information:
C:\Program Files\ArcGIS\DataStore\tools>configuredatastore fbustamonte.esri.com siteadmin siteadmin C:\temporal\data --stores spatiotemporal
Configuring data store(s). Initial configuration may take a few minutes. When configuring an upgraded data store, this process may take several hours depending on the size of your data. Please wait...
Configuring data store....
Error encountered: Machine 'https://localhost:2443/arcgis/datastoreadmin' returned an error. 'Attempt to configure data store failed.
Caused by: 'spatiotemporal' data store is not installed in the current configuration. On Windows use the Modify option to select additional features from Add Remove Programs. On Linux, modification of the installed data store type is not supported. Consider installing on a separate machine. Consult documnetation for more information on specific usage.
Cause
Some featires may be missing from the installation.
Solution or Workaround
To correct this, navigate to the ArcGIS Data Store Setup wizard by the following steps:
  1. On Windows, search for and open the Add or Remove Programs app.
Search results for Add or remove programs
  1. Click ArcGIS Data Store 11.2, select Modify, and select Next, as shown in the images below.
Prompt to modify or uninstall data store
Selecting Modify in the Setup options
  1. Select the Data Store to install the required feature for, and select one of the options in the drop-down box, as shown in the next images.
Selecting the necessary data store features
Option to install features on the local hard drive.
  1. Click Next and click Install.
Install prompt in setup dialog
This will restart ArcGIS Data Store.
You should now be able to install/configure the data store using either the ArcGIS Data Store Configuration Wizard or by using the configuredatastore.bat utility.
Finishing the setup
Article ID: 000031890
Software:
  • ArcGIS Data Store
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
