Frequently asked question
How do I select by attributes or create a query for a date field in ArcMap?
Answer
Special DBMS-dependent delimiters are used for querying date fields. If you don't use a delimiter, or use an incorrect one, you will get an error message.
The following query examples will select a date in a layer based on Microsoft Access personal geodatabase data:
Code:
[DATE_FIELD] = #1970/8/17#
Code:
[DATE_FIELD] = DateSerial(1970,8,17)
Coverages, shapefiles and SDE geodatabases use a different standard:
Code:
"DATE_FIELD" = date '1970/8/17'
You should use native DBMS date formats when working with SDE geodatabases.
For more information, click the Help button in the Select Menu, Select by Attributes choice.
Article ID:000002752
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
