Frequently asked question
<%@ page import="com.esri.aims.mtier.io.*,com.esri.aims.mtier.model.map.layer.FeatureLayer, com.esri.aims.mtier.model.map.layer.query.*,com.esri.aims.mtier.model.acetate.Point, com.esri.aims.mtier.model.acetate.Points,com.esri.aims.mtier.model.acetate.Polygon, com.esri.aims.mtier.model.acetate.Hole,com.esri.aims.mtier.model.acetate.Ring" %> <jsp:useBean id="connection" class="com.esri.aims.mtier.io.ConnectionProxy" scope="page" /> <jsp:useBean id="map" class="com.esri.aims.mtier.model.map.Map" scope="page" /> <HTML><HEAD><TITLE>Geometry Test</TITLE></HEAD> <BODY bgcolor="#ffffff"><p align="left"> <% //define server parameters String hostName = "localhost"; //replace with app. server host name int port = 5300; //replace with app. server port number String serviceName = "world"; //replace with image service name //define where expression String whereExpression = "CNTRY_NAME='South Africa'"; //replace with where expression for filter //define layer index int index = 1; //replace with layer index //set connection parameters connection.setConnectionType(connection.TCP); connection.setHost(hostName); connection.setPort(port); connection.setService(serviceName); //initialize map map.initMap(connection, 0, true, true, true, true); map.setWidth(500); map.setHeight(350); //get feature layer and setGeometry=true FeatureLayer fLayer = (FeatureLayer)map.getLayers().item(index); map.getLayers().setGeometry(true); //create and apply filter to layer com.esri.aims.mtier.model.map.layer.query.Filter filter = new com.esri.aims.mtier.model.map.layer.query.Filter(); filter.setWhereExpression(whereExpression); fLayer.setFilterObject(filter); GeometryRecordset geometry = new GeometryRecordset(); //get current ArcXML request prepared by Map object String arcxmlReq = map.getArcXML(); //send String axl request and get back String response String arcXMLResponse = map.sendArcXML(arcxmlReq,map.GET_FEATURE); // Stores all the Geometry Result after parsing java.util.Vector vectorGeometry = new java.util.Vector(); vectorGeometry = geometry.getGeometry(null,null,arcXMLResponse); //print out geometry of each parts for (int i=0;i<vectorGeometry.size();i++){ // Iterate through only Polygon Object if (vectorGeometry.get(i) instanceof Polygon){ Polygon polygon = (Polygon) vectorGeometry.get(i); out.println("Polygon - Ring Count : " + polygon.getRingsCount()); out.println("<BR>"); // Iterate through only Ring Object Ring ring = null; for (int j=0;j<polygon.getRingsCount();j++){ ring = polygon.getRing(j); for (int k=0;k<ring.getHolesCount();k++){ Hole hole = ring.getHole(k); Points pts = hole.getPoints(); for (int l=0;l<pts.getCount();l++){ Point tPoint = pts.getPointObject(l); out.println("Hole: X = "+ tPoint.getX() + ",Y="+ tPoint.getY()); out.println("<BR>"); } } Points ringPoints = ring.getPoints(); for (int k=0;k<ringPoints.getCount();k++){ Point tempPoint = ringPoints.getPointObject(k); out.println("Ring " + (j+1) + " : X = "+ tempPoint.getX() + ",Y="+ tempPoint.getY()); out.println("<BR>"); } out.println ("******************************"); out.println("<BR>"); } } } %> </td></tr></table> </BODY> </HTML>
Article ID:000006506
Get help from ArcGIS experts
Download the Esri Support App
