PROBLEM
Redirection URL requests with trailing parameters fail in some Mozilla and Netscape browsers. Using the Hyperlink tool in an ArcIMS HTML Viewer may fail to load the associated URL.
For example, this hyperlink may fail to load:
http://esri.org/monitoringdata/StationInfoB.asp?jday=&property=&chartyear=&StationID=703
Some versions of Mozilla and Netscape browsers perform the parsing of trailing parameters differently.
In ArcIMSparams.js set
var useHyperLink=false;
This disables the Hyperlink tool and the corresponding button in the HTML Viewer.
If an Identify or Select command is performed on the layer, the hyperlink can be selected from the results window.
Get help from ArcGIS experts
Download the Esri Support App
