PROBLEM
After updating the ArcGIS Server license, users may experience issues publishing a hosted feature layer, even though the ArcGIS Server licenses were updated properly. When examining the log files, the following error may occur:
"Error: Failed to connect to the database. No ArcGIS Server license found. Contact your geodatabase administrator to update license."
The relational geodatabase also fails to validate. This is the same error the appears if you have not updated the Enterprise geodatabase. However, unlike an Enterprise geodatabase, the Data Store cannot be authorized using the geoprocessing tools in ArcMap or ArcGIS Pro. Instead, use the ArcGIS Data Store command utility reference.
The error typically occurs when the Data Store is unable to receive data from the client during the time the ArcGIS Server license was updated.
C:\programfiles\ArcGIS\DataStore\tools
cd C:\programfiles\ArcGIS\DataStore\tools
C:\programfiles\ArcGIS\DataStore\tools>updatelicense.bat
Article ID: 000023537
Get help from ArcGIS experts
Download the Esri Support App
