ERROR
GXCovProp <!> Run-time error '6': Overflow
Error Message
Adding new tics to coverage in ArcCatalog returns this error:
GXCovProp
Overflow
Cause
Tic needs an ID.
Solution or Workaround
  1. Start ArcCatalog and create a new coverage.
    A. Navigate to workspace
    B. Right-click on workspace
    C. Select New
    D. Select Cover
    E. Add applicable information
    F. Click Finish
  2. Right-click cover name and select Properties
  3. Select the Tics and Extent tab
  4. Click Add
  5. Move cursor to X column and select a cell.
    This step is necessary to avoid the error
  6. Move cursor to ID column and select a cell. Type in the necessary value.
  7. Move cursor to X column and select cell. Type in the necessary value.
  8. Move cursor to Y column and select cell. Type in the necessary value.
  9. Click Update
    Repeat steps 4 through 9 for additional tics.
Article ID: 000002024
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
