PROBLEM
This occurs when the interval for the graticule is less than three degrees latitude/longitude and the data frame is rotated. This problem persists even after refreshing the display.
This is a known problem. To speed processing, graticules currently use an algorithm that does not account for rotated data frames if the graticule interval is less than three degrees latitude/longitude.
If possible, select a graticule interval of three degrees latitude/longitude or greater, in the Intervals tab of the Reference System Properties dialog box. ![[O-Image] The Interval tab of the Reference System Properties dialog](https://webapps-cdn.esri.com/CDN/support-site/technical-articles-images/000002883/00N39000003LL2C-0EM39000000wcVa.png)
Article ID: 000002883
Get help from ArcGIS experts
Start chatting now
