HOW TO
Steps to get the selected object in ArcMap's Table of Contents (TOC) using VBA.
Code:
Dim pDoc As IMxDocument
Dim pCV As IContentsView
Set pDoc = ThisDocument
Set pCV = pDoc.CurrentContentsView
Contents View is a tab in ArcMap's TOC. ArcMap has two contents views, Display and Source.
Code:
Dim pFLayer As IFeatureLayer
Dim mySet As esriCore.ISet
Set mySet = New esriCore.Set
If (TypeOf pCV.SelectedItem Is IFeatureLayer) Then
Set pFLayer = pCV.SelectedItem
Debug.Print pFLayer.Name
ElseIf (TypeOf pCV.SelectedItem is ISet) Then
Set mySet = pCV.SelectedItem
Set pFLayer = mySet.Next
Do Until pFLayer Is Nothing
Loop
End If
The return value for IContentsView.SelectedItem is of type variant because there are many possible objects that can be returned. In the Display tab, the selected item could be a map, layer, or a legend group object. In the Source tab, the selected item could be any of the above plus a Table, Feature Dataset or Workspace. If multiple items are selected a Set object is returned.
Article ID:000002527
Get help from ArcGIS experts
Download the Esri Support App
