HOW TO
Get the full path of a layer using ArcObjects
Summary
This article contains a code sample that shows how to get the full path of a layer using VBA.
Procedure
  1. Open ArcMap.
  2. Open the Visual Basic Editor.
    In ArcMap, select Tools > Macros > Visual Basic Editor.
  3. In the Project Explorer window, expand Project.mxt and select ArcMap Objects > ThisDocument then right-click and select View Code.
    [O-Image] Visual Basic Project  Explorer
    Code in the Project's ThisDocument code module will only run in the current map document. If you want to store the code in all your map documents open the Normal.mxt ThisDocument code module instead.
  4. Paste the following code into the code module.
    Code:
    Sub GetLayerPath()
    Dim pDoc As IMxDocument
    Set pDoc = ThisDocument
    'Get the first map in the document
    Dim pMap As IMap
    Set pMap = pDoc.FocusMap
    'Get the first layer in the map
    Dim pLayer As IFeatureLayer
    Set pLayer = pMap.Layer(0)
    'Get the feature class for the first layer
    Dim pFc As IFeatureClass
    Set pFc = pLayer.FeatureClass
    'Gets the dataset for standalone feature class
    Dim pDataset As IDataset
    Set pDataset = pFc
    Dim pWorkspace As IWorkspace
    Set pWorkspace = pDataset.Workspace
    Debug.Print pWorkspace.PathName
    End Sub
  5. Close the Visual Basic Editor.
  6. Run the code.
    A. Click Tools > Macros > Macros to display the Macros dialog box.
    B. Select a macro and click Run.
Article ID:000004948
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
