PROBLEM
GeoProcessing Wizard output does not maintain M, Z, or Point ID values
If you use the ArcMap GeoProcessing Wizard on data that has M, Z, or Point ID values, these values are not maintained in the output. The following operations are affected: Dissolve, Merge, Clip, Intersect, and Union.
Cause
The data model used by the ArcMap GeoProcessing Wizard does not support update or maintenance of M, Z, or Point ID values.
Solution or Workaround
There is no work-around for this issue.
Article ID:000002782
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
