PROBLEM
Geoprocessing tools display blank window
A geoprocessing tool launched in ArcMap or ArcCatalog may display as a blank window or return an error with an ActiveX or scripting message populated through the web browser.
[O-Image] ActiveX controls web browser error
The geoprocessing tool may look like the following image, in which the inputs are blank.
[O-Image] Geoprocessing tools Buffer blank
Cause
The Local Intranet security settings in Internet Options have been customized to disable running Active X Controls and plug-ins or Active Scripting.
Solution or Workaround
  1. Launch the Internet Options from the Control Panel.
[O-Image] Internet Options
  1. Navigate to the Security tab and select Local Intranet to change security settings.
  2. Under Security level for this zone, click the Custom level button.
[O-Image] Local intranet custom level
  1. Change the security settings for Run ActiveX controls and plug-ins to Enable.
[O-Image] ActiveX controls and plugins enable
  1. Under Scripting > Active scripting, change the settings to Enable.
[O-Image] Active scripting enable
Alternatively, the Internet Security Options can be reset to Default to resolve this issue.
Article ID: 000012060
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
