BUG
Geometry is incorrect when the Revit® units are set to Decimal Feet. This issue affects the location and scale of a feature, as shown in the following image. The values are reduced by one-third from the original value of the model, making the relationship 1:1/3 instead of 1:1
This issue is caused by an incorrect enumeration.
With access to Revit
Without access to Revit
Note: Esri is working with the third-party vendor to fix this issue.
Article ID: 000024739
Get help from ArcGIS experts
Start chatting now
