PROBLEM
Geolocation result obtained from a GeoForm web application differs from Collector for ArcGIS
First Published: May 5, 2016
Last Published: July 21, 2025
GeoForm is a configurable template that allows users to enter data through a form instead of a map's pop-up window. In some instances, the geolocation result obtained from the GeoForm web application differs from that of Collector for ArcGIS.
The functionalities of ArcGIS Collector, ArcGIS Explorer, and ArcGIS Tracker are now available in ArcGIS Field Maps. There are no new capabilities planned for these apps—all future updates will be focused on Field Maps. Migration is recommended. See ArcGIS Blog: Migrate to Field Maps for more information.
Cause
The Collector for ArcGIS application uses the GPS on the mobile device, which allows the application to retrieve location information from satellites. However, the Locate Me button in the GeoForm web mapping application derives location information from the browser. Therefore, the results may vary based on multiple factors, such as the connection type, Internet service provider (ISP), physical location, network, and browser.
Solution or Workaround
Option A
Improve the accuracy of the results by configuring the machine as an access point location for the Google Location Service. To do this, refer to the following Google Maps Help article: Configure access points with Google Location Service.
Option B
Customize the GeoForm web mapping application by downloading the source code, writing changes, and hosting the app on a server. Download the source code from the Esri GitHub page: GeoForm template.
Article ID: 000012304
Software:
  • ArcGIS Collector
  • ArcGIS Online
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
