PROBLEM
Sometimes when users export a geospatially enabled PDF from ArcGIS Pro, they see incorrect coordinates and measurements in Adobe Acrobat.
This is caused by a setting in Adobe Acrobat called “Always display latitude and longitude as WGS 1984”. This is enabled by default in Acrobat and forces the PDF into WGS 1984, which can cause incorrect coordinates or measurements if the PDF was explored with a different datum.
To correct this, uncheck the Always display latitude and longitude as WGS 1984 option as follows:
After unchecking this option, the PDF will be displayed in its correct datum, chosen upon export.
Article ID: 000032005
Get help from ArcGIS experts
Start chatting now
