PROBLEM
Geodatabase annotation displayed in the ArcMap window rotates, so it is no longer horizontal to the page when the projection of the ArcMap Data Frame is changed.
The contents of this article do not apply to splined annotation or annotation created to follow the angle of a line segment.
When geodatabase annotation is created in a specific coordinate system, the annotation is horizontal to the page. When the projection of the ArcMap Data Frame is changed to a new Coordinate System with a different Central Meridian, the annotation rotates either clockwise or counterclockwise toward the new Central Meridian.
Warning:
The script below must be installed in a saved MXD file in order to run correctly.
Code:
Option Explicit
' Author ESRI BeLux - nov 2004
Public Sub AnnoLineToPoint()
' Condition:
' - Start Edit session
' - Annotation selected (with text different from null string)
Dim pEditor As IEditor
Dim pID As New UID
Dim pEnumFeature As IEnumFeature
Dim pFeature As IFeature
Dim Count As Long
Dim pActiveView As IActiveView
Dim number_feature As Integer 'Nombre de features modifiés
number_feature = 0
pID = "esriEditor.Editor"
Set pEditor = Application.FindExtensionByCLSID(pID)
pEditor.StartOperation
Set pEnumFeature = pEditor.EditSelection
pEnumFeature.Reset
Set pFeature = pEnumFeature.Next
Do Until pFeature Is Nothing
Dim pElement As IElement
Dim pAnnoF As IAnnotationFeature
Set pAnnoF = pFeature
Set pElement = pAnnoF.Annotation
If TypeOf pElement Is ITextElement Then
If TypeOf pElement.Geometry Is IPolyline Then
Dim pGeometry As IGeometry
Dim pPointColl As IPointCollection
Set pGeometry = pFeature.Shape
Set pPointColl = pGeometry
Dim pPointColl2 As IPoint
Set pPointColl2 = New Point
'Place the point of the point on the middle of the line
'The text is place in a polygone.
Dim newx As Double, newy As Double
newx = ((pPointColl.Point(0).X + pPointColl.Point(3).X) / 2)
newy = ((pPointColl.Point(0).Y + pPointColl.Point(3).Y) / 2)
pPointColl2.PutCoords newx, newy
Set pGeometry = pPointColl2
pElement.Geometry = pGeometry
Dim pTextElement As ITextElement
Set pTextElement = pElement
Dim pSimpTextSymbol As ISimpleTextSymbol
'we need to reset the offset because the feature shape doesn't
'represent it. Otherwise, the text will move if it has offsets
Set pSimpTextSymbol = pTextElement.Symbol
pSimpTextSymbol.Angle = 0 ' Force the texte to be horizontal
pTextElement.Symbol = pSimpTextSymbol
Set pElement = pTextElement
pAnnoF.Annotation = pElement
Set pFeature = pAnnoF
pFeature.Store
number_feature = number_feature + 1
'do nothing for lines: we are working with points here
End If
End If
Loop
pEditor.StopOperation "Convert Line to point annotations for " & number_feature & " features."
pEditor.Display.Invalidate Nothing, True, esriAllScreenCaches
End Sub
Article ID:000009577
Get help from ArcGIS experts
Download the Esri Support App
