ERROR
Geocoding using a Microsoft Access database table as the address table returns 'Syntax error (missing operator) in query expression'
Last Published: February 12, 2024
Error Message
Geocoding using a Microsoft Access database table as the address table results in the following error:
"There was an error trying to process this table.
General function failure [table name]
Syntax error (missing operator) in query expression 'field name'."
Cause
The address table contains a field or fields that either begin with a number, contains a space, or contains the '&' or '^' symbols.
Solution or Workaround
Edit the table using Microsoft Access to remove the number, space, or odd character in the field name.
Article ID: 000006082
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
