PROBLEM
Geocoding toolbar in ArcMap is not showing any locators
First Published: December 15, 2020
Last Published: December 15, 2020
When opening the Geocoding toolbar in ArcMap and there are default locators set in the DefaultLocators.xml file, these should be listed in the toolbar. However, ArcMap sometimes opens and only lists <Add Address Locator...> on the Manage Address Locators drop-down on the Geocoding toolbar, even though the DefaultLocators.xml file exists and lists other locators.
image of the Manage Address Locators drop-down
Cause
This can occur when the DefaultLocators.xml has become corrupted.
Solution or Workaround
To resolve this:
  1. Send a DefaultLocators.xml file from an environment not experiencing this issue.
    • Use any DefaultLocators.xml from an account that is able to see the locators populate the drop-down in ArcMap's Geocoding toolbar.
  2. Navigate to the DefaultLocators.xml file in:
C:\Program Files (x86)\ArcGIS\Desktop10.x\Locators
​​​image of file browser
  1. Rename or delete the old DefaultLocators.xml.
  2. Replace it with the new DefaultLocators.xml it in the same path as in Step 2, above.
  3. Restart ArcMap.
This should allow editing the new DefaultLocators.xml and successfully adding locators to the list.
Article ID: 000024263
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
