HOW TO
The concentric ring model, also known as the Burgess model, is used to categorize data based on concentric circles around a common centroid.
This spatial analytical process can be accomplished using SQL, an st_geometry attribute and the st_distance operator.
The instructions provided demonstrate how to execute a SQL statement to generate concentric rings and a categorized result set. The SQL consists of multiple SQL statements using a UNION to merge each result set into one result set with an attribute to identify the category (distance) where each row resides.
The following example uses a point layer representing lightning strikes. The objective is to categorize the lightning strikes based on a set of equivalent distances, 0 to 1000 Meters, 1001 to 2000 Meters and 2001 to 3000 Meters.
Code:
SQL> SELECT 1 AS RING, a.objectid, st_distance(a.shape,b.shape) AS DISTANCE
FROM lightstrk a, lightstrk b
WHERE b.objectid = 100000
AND st_intersects(a.shape,st_buffer(b.shape,1000)) = 1
AND a.objectid != 100000
UNION
SELECT 2 AS RING, a.objectid, st_distance(a.shape,b.shape) AS DISTANCE
AND st_intersects(a.shape,st_buffer(b.shape,2000)) = 1
AND st_distance(a.shape, b.shape) > 1000
AND st_distance(a.shape, b.shape) <= 2000
UNION
SELECT 3 AS RING, a.objectid, st_distance(a.shape,b.shape) AS DISTANCE
AND st_intersects(a.shape,st_buffer(b.shape,3000)) = 1
AND st_distance(a.shape, b.shape) > 2000
ORDER BY DISTANCE;
RING OBJECTID DISTANCE
1 1391406 424.3
1 15449 659.7
1 1560188 851.2
1 13709 979.4
2 1290559 1383.5
2 1468424 1392.7
2 897690 1421.5
2 1937778 1489.2
2 256875 1763.1
2 576109 1903.6
2 974152 1954.8
3 15390 2194.1
3 572980 2452.0
3 1551819 2786.2
Code:
Article ID: 000009488
Get help from ArcGIS experts
Start chatting now
