BUG
Running the Summary Report tool using an ArcGIS Online Data Source returns Error 999999.
Last Published: December 5, 2022
Running the Summary Report tool using an ArcGIS Online Data Source without sufficient credits returns Error 999999.
Cause
The Summary Reports tool consumes credits. When insufficient credits are available, the tool is expected to fail.
If users are unaware of their current credit balance and encounter the Error 999999 when running this tool in ArcGIS Pro, it is advisable to check their credit balance in ArcGIS Online.
This workflow can also be tested in Business Analyst Online to confirm that they have insufficient credits to run reports.
Workaround
  • If available, use local data to run Business Analysis.
  • Work with the ArcGIS Online Administrator to increase credit allotment or credit balance for the portal user.
BUG-000153458 : Running the Summary Report tool using ArcGIS Online Data Source without sufficient credits returns Error 999999.
Article ID:000028741
Software:
  • ArcGIS Business Analyst Pro
  • Business Analyst
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
