HOW TO
Format a number field to a text field with currency formatting
First Published: May 5, 2016
Summary
When formatting a number field to display as currency, only the value displays in the Table view.
To use currency formatting for analysis, annotations, and so forth, the values must be formatted in a text field. The instructions provide a sample code to convert a number field to a text field with currency formatting. For example, '1500000.30' converts to '$1,500,000.30'.
Procedure
  1. Add a text field to the feature class.
  2. Right-click the new text field > Field Calculator.
  3. Select the Python parser, and type the following code in the code block.
    Code:
    '$' + '{:,}'.format( !Currency_Field! )
    Make sure to change !Currency_Field! to the name of the field that has the currency values.
  4. To round values, check the dialog "Show Codeblock" and type the following code into the Pre-Logic Script Code window.
    Code:
    def currency(x):
    val = round(x,2)
    out = '$' + '{:,}'.format(val)
    right = len(out.split('.')[1])
    if right < 2:
    return out + '0'
    else:
    return out
    Paste the following code (and change the name of the field in the code to the field being converted) in the bottom window.
    Code:
    currency( !Currency_Field! )
Article ID: 000012384
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
