BUG
When adjusting the dimensions of a levee in the Flood Planning map, the volume of required materials and the associated cost appear to decrease when the height of the levee is increased.
The levee volume calculation is performed by the Attribute Assistant using an expression stored in the Dynamic Value table. The expression provided with the 10.1 and 10.1 SP1 releases of the Flood Planning map contains an error.
This error has been corrected at the 10.2 release.
(([SHAPE_Length]*[HEIGHT]*([SIDESLOPE]*[HEIGHT]+[TOPWIDTH]))/27)
This expression assumes the input measurements are feet and the output volume is cubic yards. To use other units, adjust the conversion factor accordingly.
Article ID: 000011820
Get help from ArcGIS experts
Start chatting now
