ERROR
Floating point exception
Last Published: September 22, 2020
Error Message
When a project or layout is opened, ArcView returns the following error:
Floating Point Exception
Cause
The most common cause is a conflict between ArcView and the default printer driver.
Solution or Workaround
  1. Determine if there is a conflict by changing the default printer. See the link in the Related Information section below.
    If a Floating Point Exception error is still displayed, see Related Information. If not, proceed to step 2.
    If only one printer is installed on the computer, change the printer to a test printer.
    Other printers, including the previous default, are still available. Select them  from the drop down list in the Print dialog box.
  2. Install the most recent version of the printer driver available. This is usually found at the printer manufacturer's web page.
Article ID:000004767
Software:
  • ArcGIS Desktop
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
