HOW TO
Fix Data Sources After Cloning ArcGIS Experience Builder Applications
First Published: July 22, 2024
Last Published: July 22, 2024
Summary
There is an existing defect that occurs when cloning ArcGIS Experience Builder applications using the ArcGIS API for Python.  The defect causes the cloned experience to have broken data sources.  The data sources point to the item ID of the hosted feature layer rather than the cloned web map in the 'config/config.json' file, rendering the cloned app uneditable. The defect is expected to be fixed in an upcoming release.
This workflow will be helpful for ArcGIS Location Platform accounts migrating ArcGIS Experience Builder applications to ArcGIS Online organizational accounts.
The following workflows update the ‘config/config.json’ with the latest published version of the Web Experience using the items data JSON.
Procedure
Option 1: ArcGIS API for Python Workflow
  1. Get the ItemID of the Web Experience.
  2. Run the following Python script from a Jupyter Notebook interface using the ItemID.
gis = GIS("home")
item=gis.content.get("[ItemID]")
item_config=item.resources.get("config/config.json")
item_data=item.get_data(try_json=True)
item.resources.update(folder_name="config", file_name="config.json", text=item_data)
Option 2: AGOL Assistant Workflow
  1. Login to https://assistant.esri-ps.com/.
  2. Select the Web Experience and click View Item JSON.
  3. Copy the JSON content in the JSON Editor’s Data tab.
  4. In the Resources tab, select the ‘config/config.json’ resource.
  5. Click Edit Resource and replace the JSON with the JSON copied from the Data tab in step 3.
  6. Save.
Disclaimer: ArcGIS Assistant is a community-driven project from Esri Professional Services. While all of the requests from Assistant use supported ArcGIS REST API operations, doing so could leave your content in a broken or reduced state, and Esri Technical Support will not be equipped to help you with that situation. https://guide.assistant.esri-ps.com/docs/faq#is-arcgis-assistant-supported-by-esri
Article ID: 000033170
Software:
  • ArcGIS API for Python
  • ArcGIS Experience Builder Developer
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
