PROBLEM
Find Disconnected trace task is slow, even when the size of the results returned is small
First Published: May 5, 2016
Performing a Find Disconnected trace task on a large geometric network takes a long time to complete, even when the result of the trace is a small number of features.
Cause
The Find Disconnected trace task returns all features in the geometric network that cannot be reached from the given input flags. In order to accomplish this, the trace task must look at all features in the geometric network.
Solution or Workaround
Run the Find Disconnected trace task sparingly on large geometric networks.
You can use VB to create custom trace tasks that limit the extent of the network to be searched when finding disconnected network elements.
Article ID: 000003012
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
