HOW TO
When working with ArcGIS Web AppBuilder, it may be necessary to apply filters on multiple layers. Additionally, it may also be a requirement to apply asynchronous filters, meaning different filters for different layers that display in the same map.
For example, assume you have a layer with locations of Supermarket A, and a second layer with Supermarket B. Both Supermarket A and Supermarket B layers have an attribute field 'OpenDate' which contains the dates of when the stores first opened. You may need to create a filter to find which stores opened on or after a given date. You may also need to create an asynchronous filter to find which Supermarket A locations opened after January 1, 2015, and which Supermarket B locations opened after July 1, 2018. Both filtered layers must be displayed together on the Web AppBuilder map.
Asynchronous filters can be applied to multiple layers by using the Group Filter widget.
Article ID: 000034352
Get help from ArcGIS experts
Start chatting now
