PROBLEM
Features disappear from the HTML Viewer after panning or zooming
When zooming in to a layer with scale dependencies set in the HTML viewer, some features disappear from the main map.
Cause
New layers were added to the existing map configuration file and the selFieldList[] array within the ArcIMSParam.js file was not updated to reflect these new layers.
Solution or Workaround
Follow the steps below.
  1. Open the ArcIMSParam.js file in a text editor, within the HTML Web site folder.
  2. Navigate to the section of code where the selFieldList[] array is defined. For example: var selFieldList = new Array();
  3. Enter additional selFieldList parameters to reflect the new layers referenced in the map configuration file. For example,
    Code:
    selFieldList[22]="#ALL#";
    selFieldList[23]="#ALL#";
    The numeric value above represents the 'id' value for each layer in the map configuration file"
Article ID:000007992
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
