ERROR
When attempting to run startup.bat from <drive>:\jakarta-tomcat-3.2\bin, the following error message occurs:
FATAL:java.net.BindException: Address in use: bind
at java.net.PlainSocketImpl.socketBind(Native Method)
at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:390)
at java.net.ServerSocket.<init>(ServerSocket.java:173)
at java.net.ServerSocket.<init>(ServerSocket.java:124)
at org.apache.tomcat.net.DefaultServerSocketFactory.createSocket(Default
ServerSocketFactory.java:97)
at org.apache.tomcat.service.SimpleTcpEndpoint.startEndpoint(SimpleTcpEn
dpoint.java:186)
at org.apache.tomcat.service.SimpleTcpConnector.start(SimpleTcpConnector
.java:142)
at org.apache.tomcat.core.ContextManager.start(ContextManager.java, Comp
iled Code)
at org.apache.tomcat.startup.Tomcat.execute(Tomcat.java:157)
at org.apache.tomcat.startup.Tomcat.main(Tomcat.java:163)
Another application or service is already accessing port 8080. On Windows, it could be a service installed on some Dell servers. The service name is 'dellw3j' and it uses port 8007.
See Related Information to download fport v1.33. This program reports all open TCP/IP and UDP ports and maps them to the owning application.
Article ID:000004696
Get help from ArcGIS experts
Download the Esri Support App
