ERROR
The following error occurs when starting ArcInfo:
Error: FATAL ERROR Segmentation Violation
There may be syntax or typographic errors in the license file, such as a missing underscore or secondary encryption string in a FEATURE line.
Code: FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor info="8CDZFL7B5R6G6RH9L023" ck=15Correct:
Code: FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor_info="8CDZFL7B5R6G6RH9L023" ck=15Example: missing secondary encryption string:
Code: FEATURE ARC/INFO ESRI 8.01 01-jan-00 1 3BFF602151F669CB9349 vendor_info="" ck=15Correct:
Article ID:000002082
Get help from ArcGIS experts
Download the Esri Support App
