Frequently asked question
Why is there only a strip of or no data at all returned with operations such as Mosaic in the Raster Calculator?
Answer
The analysis extents have not been properly set up. Under the Spatial Analyst menu there is a selection for Options. This will open the analysis Options dialog where the analysis extent can be set (see the Extent tab).
In ArcMap, the default setting for Analysis Extent is "Intersection of Inputs". This setting will only consider the area of overlay, if any, between raster datasets. This setting should be changed to "Union of Inputs" when performing operations where more than one raster is being used; like Mosaic or Merge.
Please reference chapter 6 of the "Using ArcGIS Spatial Analyst" for a complete description, instructions, illustrations and an explanation of the analysis environment in Spatial Analyst.
Article ID:000005645
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
