Frequently asked question
Why is the output raster empty when extracting a raster using the IExtractionOp::Polygon method?
Answer
If the input raster and the polygon object are in different spatial references, the polygon object used to clip the image does not get projected.
Make sure the input raster and the polygon object have the same spatial reference. If they have different spatial references, or you require an output with a different spatial reference than the inputs, then project the inputs to the required spatial reference before performing the extract operation.
Article ID:000003628
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
