Frequently asked question
The option to export feature classes to shapefiles is no longer available in the Export Features window in the latest version of ArcGIS Pro 3.x. However, feature classes can still be exported to shapefiles using any of the methods described in this article.
Instead of using the Export Features option from the Contents pane, use the Feature Class To Shapefile tool to export feature classes to shapefiles.
Note: To export only certain features of a feature class, use the selection tools to select the features before specifying the Input Features parameter. For more information, refer to ArcGIS Pro: Select features interactively.
The option to export feature classes to shapefiles is available from the Catalog pane. The 'Feature Class To Shapefile...' option uses the Feature Class To Shapefile tool.
To export feature classes from the Export Features window, remove the geodatabase connection from the Output Feature Class parameter and add a shapefile extension. For more information on shapefile extensions, refer to ArcGIS Pro: Shapefile components and file extensions.
The image below shows the shapefile added to the map and located in the Catalog pane.
Article ID: 000030556
Get help from ArcGIS experts
Start chatting now
