Frequently asked question
Why don't raster catalogs rotate when the Data Frame is rotated?
Answer
When you rotate the data frame, vector and raster layers rotate, but raster catalogs display without any rotation. This is because raster catalogs do not support data frame rotation in ArcGIS 8.2.
You can only view the component rasters of the raster catalog with rotation when the data frame is rotated, if you load each of the component rasters individually as separate raster layers. Rasters in a raster catalog are meant to be already pre-processed and have the correct rotation.
Article ID:000003219
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
