Frequently asked question
Why does the Geostatistical Analyst variogram/covariance cloud diagram use a maximum of 300 pairs of samples?
A semivariogram, covariance, or cross-covariance cloud depicts all possible pairs of points for a range of lag distances. The default dataset of 300 points totals nearly 45,000 point pairs, and even these can be difficult to display and interpret.
Datasets with hundreds or thousands of samples should be restricted to smaller domains, to avoid overcrowding the variogram/covariance cloud diagram.
Geostatistical Analyst default values can be changed using the ArcMap Advanced Settings Utility.
For ArcGIS, versions up to ArcGIS 8.1 run AdvAMSet.exe located in the ArcObjects Developer Kit\Utilities\VBAdvancedSettingsUtility.
For versions 8.1.2 and above, run AdvancedArcMapSettings.exe located in %ARCHOME%\Utilities.
Article ID: 000005108
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
