Frequently asked question
Why does my raster dataset no longer have an AUX file in ArcGIS 9.2?
Answer
At the release of ArcGIS 9.2, two different libraries are used to read raster formats: RDO and GDAL.
With 9.2, all GDAL format rasters have an AUX.XML file created, that stores projection, statistics, and other additional information. RDO format rasters always use the AUX file but are also capable of using the AUX.XML format as well.
Since all versions prior to 9.2 just use the AUX file to store this information, there is no capability for these versions to read the AUX.XML; it is not backwards compatible. This is a known limit for GDAL rasters.
When trying to define a projection for GDAL rasters they will display properly in 9.2 but not in 9.1/9.0/8.X. RDO rasters should behave the same through all versions.
In short, GDAL rasters will have AUX.XML in 9.2. RDO rasters will always have AUX in all versions.
Prior to 9.2 all rasters were read using RDO.
The following are what is supported by GDAL and RDO at ArcGIS 9.2:
GDAL - BMP, GIF, JPEG, JPEG2000, MrSID, PNG, BIL, BIP, BSQ, ADRG, CADRG, PIX, BSB, DEM, XPM, ECW
RDO - GRID, IMG, TIFF,CIB, ASRP, USRP, DTED, ERM, LAN, RAW, CIT, COT, NITF
Article ID:000009157
Software:
  • ArcMap 9 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
