Frequently asked question
Why does a continuous raster dataset, loaded into a geodatabase, become discrete with a colormap?
Answer
A continuous raster with a data depth of eight or less bits, and no colormap, will become a discrete raster of the same data depth with a colormap after being loaded into a geodatabase. This means the same file-based raster, which used the stretched renderer by default, will use the unique values renderer as the default after being loaded into a geodatabase.
In order to support a table for eight bit or lesser depth data in the geodatabase, a colormap table is created. Therefore, the data becomes discrete and color-indexed. By default it will be rendered with unique values, but will appear very similar as when it was a file-based raster layer.
Article ID:000003150
Software:
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
