Frequently asked question
Why are the Save and Discard edit buttons disabled in the default version of a branched versioned dataset?
When working with branch versioned data, if edits are performed directly on the Default version of the geodatabase, the Save and Discard edit buttons are disabled by default. This is because edits made on the Default version cannot be undone.
Image of the ArcGIS Pro Save and Discard edits button being grayed out
Both buttons remain disabled even if the option to automatically save edits is not enabled.
Image of the automatically saved edits button
As the Default version is the ancestor of every other version in a geodatabase, and usually represents the published version, it is essential to protect it by setting the access level to Protected. This will prevent accidental alterations or corruption of the Default version. Refer to ArcGIS Pro: Protect the default version for more information.
Article ID: 000022261
Software:
  • ArcGIS Pro 2 x
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
