Frequently asked question
Which ArcObjects Java library should be referenced in ArcGIS Server installation envrionment?
Answer
When working with applications developed with ArcObjects SDK for Java, the arcobjects.jar library from its running environment must be referenced. In an environment with ArcGIS Server installed, the library named arcobjects.jar can be found in the following path:
<ArcGIS Server installation directory>\framework\lib\arcobjects.jar
or
<ArcGIS Server installation directory>\framework\runtime\ArcGIS\framework\lib\arcobjects.jar
Which file should be used for the application?
The file that should be referenced is:
When developing with the ArcObjects SDK for Java and ArcGIS Eclipse plug-ins, the ArcObjects Library from ArcGIS Server can be added if it's available in the same environment. Notice that this updates the build path with the arcobjects.jar file from the same aforementioned path.
Article ID:000022609
Software:
  • ArcGIS Server
  • ArcObjects SDK for the Java Platform
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
