Frequently asked question
Where is the documentation for ArcIMS 4.0.1 on Windows?
Answer
Most of the documentation for ArcIMS 4.0.1 has been moved from the Start menu. This document indicates where the ArcIMS documentation may be found.
BASIC GUIDES
ArcXML Guide:
Code:
...\ArcGIS\ArcIMS\Documentation\ArcXML_Guide\ArcXML_reference.htm
Installation Guide:
Code:
...\ArcGIS\ArcIMS\Documentation\Install.htm
VIEWER CUSTOMIZATION DOCUMENTATION
Customizing the HTML Viewer:
Code:
...\ArcGIS\ArcIMS\Documentation\CustomizingHTMLViewer.pdf
Customizing the Java Viewer:
Code:
...\ArcGIS\ArcIMS\Documentation\CustomizingJavaViewer.pdf
Customizing Metadata Explorer:
Code:
...\ArcGIS\ArcIMS\Documentation\CustomizingMetadataExp.pdf
CUSTOMIZING WITH CONNECTORS DOCUMENTATION
Customizing with the Cold Fusion Connector:
Code:
...\ArcGIS\ArcIMS\Documentation\CustomizingColdFusion.pdf
Customizing with the ActiveX Connector:
Code:
...\ArcGIS\ArcIMS\Documentation\ActiveX_Connector\Customizing ActiveX.pdf
ActiveX Connector Object Model Diagram:
Code:
...\ArcGIS\ArcIMS\Documentation\ActiveX_Connector\ActiveX_OMD.pdf
Customizing with the Java Connector:
Code:
...\ArcGIS\ArcIMS\Documentation\Java_Connector\CustomizingJavaConnector.pdf
Java Connector Object Model Diagram:
Code:
...\ArcGIS\ArcIMS\Documentation\Java_Connector\JavaConnectorOMD.pdf
Java Connector Tag Library Reference:
Code:
...\ArcGIS\ArcIMS\Documentation\Java_Connector\Taglibrary_reference.htm
Java Connector Java Doc:
Code:
...\ArcGIS\ArcIMS\Documentation\Java_Connector\api_reference.htm
METADATA DOCUMENTATION
Metadata Documentation:
Code:
...\ArcGIS\ArcIMS\Documentation\ArcIMSMetadata.pdf
Code:
Article ID:000006134
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
