Frequently asked question
Where in ArcMap can I use the text formatting tags added for ArcGIS 8.2?
Answer
With a few exceptions, you can use text formatting tags anywhere in ArcMap where you can specify a text string and a text symbol. The text string can be either typed in by you, or derived from tabular data.
Where text formatting tags are supported:
· Map annotation
· Geodatabase annotation - in field(s)
· Geodatabase annotation - in expressions
· Labels - in field(s)
· Labels - in expressions
· Legend titles
· Legend layer names
· Legend headings
· Legend labels
· Legend descriptions
· ArcMap Main Menu > Insert > Title
· ArcMap Main Menu > Insert > Text
· Scale Bars - units label
· Scale Text - unit labels
· Graphic Text - Simple text and Callout text
Where text formatting tags are supported, but only after converting to graphics and ungrouping down to the level of individual dumb text elements:
· Scale Bars - all other text
· Grid labels
· Graticule labels
Where text formatting tags are not supported (exceptions to above cases):
· Table window
· Table of Contents - all text
· Graphs - all text
· Reports - all text
Where formatting tags may be supported depending on what ArcGIS version is being used (possible exceptions to the above cases):
Formatting tags are supported for the following in ArcGIS version 8.3 and layer, but not in ArcGIS version 8.2 and earlier:
· Graphic Text - text created with the splined text tool
· Annotation - Geodatabase annotation projected on the fly.
Where text formatting tags are not supported:
· Table inserted into layout
· North Arrow
· Scale Text - all other text
· File > Map properties > Title
Article ID:000004761
Software:
  • ArcMap 9 x
  • ArcMap 8 x
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
