Frequently asked question
When adding a GlobalID attribute should the values be NULL in the archive class?
Answer
When adding a GlobalID attribute to an existing versioned, archive-enabled class in the geodatabase, the GlobalID values will be set for the versioned class, but the GlobalID values in the archive class will be set to NULL.
Once objects are archived to the archive class when the DEFAULT version is modified, the GlobalID values start appearing in the archive class.
This is currently a known limitation.
Article ID:000010796
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
