Answer
** Internal Publish Only! This article may contain information that is not intended for external circulation. **
SharePoint
Software Request Forms
\metro\released
This area contains all supported products. Most analysts stop here often.
\\metro
Similar to the released set at \metro\released, except these are the daily builds that have not yet made it into the next SP or release.
\\archive
This area contains the series of daily builds. This area is rarely used by Support but may be called upon to track down the version in which a bug occurred within a series of builds. Use the NonDevSetup folders in this area. These are compiled setup builds intended for non-dev use. Anything else will require direct dev involvement to even install since they've not been compiled into an installer.
QFE Team - qfeteam@esri.com
QFEs (hotfixes) are tightly controlled, but Support analysts can readily gain access to them by emailing this alias and requesting the hotfix for testing.
\\metro\QFE\Testing
This is the location of non-published updates.
Tier 1 Analyst Guide
KUBE
KBPlus
Lab Manager Policy
Required Lab Manager Naming Schemes
Scheme:<Employee>i<Incident#>
Employee example: 6007i765123
Contractor example: senti765123
ArcZone Links
