Frequently asked question
In ArcGIS Experience Builder, both the Query and Filter widgets support user-defined input and use SQL expressions to filter data based on specified criteria. While both widgets provide similar filtering capabilities, there are several key differences between them, as summarized in the table below.
Query widget |
Property |
Filter widget |
Supports attribute filters and spatial queries |
Supported query types |
Supports attribute filters only |
Creates a new output data source that can be used by other widgets |
Output method |
Does not create an output data source but applies filters directly to widgets connected to the data source |
Returns results as a separate output data source and does not directly alter the original layer |
Effect on source layer |
Directly filters the data displayed by widgets connected to the data source |
Can be resized and dragged independently on the page layout, except when the Vertical arrangement style is used |
Panel mode at run time |
Fixed panel and cannot be resized or dragged independently on the page layout, regardless of the selected arrangement style |
Supports message actions and data actions |
Actions |
Supports message actions only |
The Query and Filter widgets are designed for different workflows and serve distinct purposes in ArcGIS Experience Builder.
The Query widget executes queries and returns matching records. It provides map drawing tools and performs spatial queries using spatial relationships, such as intersect and overlap, to retrieve features within a defined area of interest. The results are stored as a separate output data source, which can be used by other widgets. Refer to How To: Display filtered data based on queries using the Feature Info widget in ArcGIS Experience Builder for more information. The widget executes individual queries per layer and does not support grouped filter logic.
The Query widget below shows the query results based on an attribute filter and a buffer distance.
In contrast, the Filter widget applies filters to an existing data source and limits the features displayed. It does not provide tools for performing spatial searches or drawing geometries on the map. However, the widget includes group filters, allowing multiple filters to be organized and applied simultaneously to one or more layers. Refer to How To: Connect filters to multiple data sources in ArcGIS Experience Builder for more information. The Filter widget directly controls what data is displayed across connected widgets using the same data source.
The experience below shows features returned using a group filter.
Article ID: 000042604
Get help from ArcGIS experts
Start chatting now
