Frequently asked question
What are the alternatives to the retired arcpy.time python module?
First Published: June 23, 2022
Last Published: August 5, 2025
Attempting to access the arcpy.time module generates an error similar to the following:
module 'arcpy' has no attribute 'time'
The arcpy.time python module was deprecated and removed at ArcGIS Pro version 3.0.
In addition to Map Time, Layer Time and Time Zone functionality in the arcpy.mp python module, ArcGIS Pro 3.0 has been updated to Python 3.9, which has additional time support. Below are examples of common workflows.
Alternatives to arcpy.time.EsriTimeDelta
There are a couple of options to use core Python, that is, non-ArcPy time deltas. Firstly, there is the datetime.timedelta type. The datetime.timedelta supports units of days, seconds, and milliseconds. Secondly, the dateutil library relativedelta type supports all date units, such as months, years, etc.
More information on datetime.timedelta and dateutil.relativedelta can be found in the Python 3.9.13 Documentation: datetime — Basic date and time types. The following is an example:
from datetime import datetime
from dateutil.relativedelta import relativedelta
time = datetime(2011, 1, 1)
for delta in range(0, 12):
    next_date = time + relativedelta(months=delta)
    print(next_date)
Starting at ArcGIS Pro version 2.8, arcpy.mp added support for LayerTime and MapTime. These classes do not use EsriTimeDeltas. LayerTime intervals are expressed as timeStepInterval and timeStepIntevalUnits. MapTime intervals are expressed as currentTimeSpan, currentTimeSpanUnits, timeStepInteval and timeStepIntevalUnits.
The MapTime class also has a timeStep method that returns a new time based on a given reference time and a time interval. The Python datetime object returned from the timeStep method can be used to set the currentTimeStart and currentTimeEnd properties. To create a temporal map series, use the timeStep method to iterate through time values.
Here is an example of LayerTime timeStepInterval:
import arcpy
aprx = arcpy.mp.ArcGISProject('C:/Project/Temperature.aprx')
m = aprx.listMaps('USA')[0]
lyr = m.listLayers('temperature')[0]
t = lyr.time
print(t.timeStepInterval)
print(t.timeStepIntervalUnits)
Here is an example of MapTime currentTimeSpan:
import arcpy
lyt = aprx.listLayouts()[0]
mf = lyt.listElements('MAPFRAME_ELEMENT')[0]
mt = mf.time
print(mt.currentTimeSpan)
print(mt.currentTimeSpanUnits)
Alternatives to arcpy.time.ListTimeZones
Use arcpy.mp.ListTimeZones. For example:
import arcpy
tzList = arcpy.mp.ListTimeZones("*Canada*")
print(tzList)
Alternatives to arcpy.time.TimeZoneInfo
Use zoneinfo, which is new in Python 3.9. More information can be found in the Python 3.9.13 Documentation: zoneinfo — IANA time zone support
Zoneinfo example 1:
from zoneinfo import ZoneInfo
tzinfo = ZoneInfo('US/Pacific')
time = datetime(2011, 1, 1, tzinfo=tzinfo)
    print(next_date, tzinfo.tzname(next_date))
Zoneinfo example 2:
from_tzinfo = ZoneInfo('US/Pacific')
target_tzinfo = ZoneInfo('US/Eastern')
from_time = datetime.now(from_tzinfo)
print("target_time =", str(from_time.astimezone(target_tzinfo)))
Article ID: 000027752
Software:
  • ArcGIS Pro
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
