Frequently asked question
What are the Advanced View Settings in ArcGlobe?
Answer
These settings are for the Near and Far Clipping Planes. These planes assist in performance optimization by clipping areas that do not fall within the application's view.
The Advanced View Settings in ArcGlobe can be accessed from the View Menu > View Settings > Advanced.
[O-Image] Advanced View Settings
There are times in ArcGlobe when the clipping planes need to be adjusted for the radial animation to appear correct. In the following example, a portion of the display is cut off because it is outside of the application's view.
[O-Image] Clipping Plane 1
By moving the Near Clipping Plane setting to the left (toward the observer), the entire area becomes visible.
[O-Image] Clipping Plane 2
Article ID:000011299
Software:
  • ArcMap
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Discover more on this topic
