Frequently asked question
What are appropriate values for the SDE DBTUNE parameter st_geom_lob_storage?
Answer
The ArcSDE DBTUNE parameter, st_geom_lob_storage, is used for defining the storage characteristics of the ST_Geometry attribute, the ST_Geometry points attribute's LOB segment storage, and the LOB's segment index.
The following example demonstrates a valid configuration string for the st_geom_lob_storage parameter, which defines the ST_Geometry attribute's storage characteristics, the point attribute's LOB segment storage characteristics, and the LOB's segment index storage characteristics.
Code:
ST_GEOM_LOB_STORAGE "STORE AS (
ENABLE STORAGE IN ROW CHUNK 8K RETENTION CACHE
TABLESPACE users_data STORAGE (INITIAL 500M PCTINCREASE 10)
INDEX (TABLESPACE users_lob_idx STORAGE (INITIAL 50M PCTINCREASE 10)))"
When the feature class is created, the ST_Geometry LOB's points are stored in the users_data tablespace with an initial 500M extents and the next extent increases by 10 percent. The ST_Geometry points LOB index is created in the users_lob_idx tables, and the initial extent is 50M and the next extent increases by 10 percent.
Oracle recommends not to define the name of the LOB segment's index and storage clause as demonstrated above and in the ArcSDE dbtune file 'INDEX (TABLESPACE users_lob_idx STORAGE (INITIAL 50M PCTINCREASE 10))'. See the following knowledge base article: Should the Oracle LOB segment's index name be specified when creating an ST_Geometry attribute? for additional information.
Article ID:000009522
Software:
  • Legacy Products
Get help from ArcGIS experts
Contact technical support
Download the Esri Support App
Go to download options
Related Information
Discover more on this topic
